Normal Topic Deleting boxes and arrows (Read 3176 times)
MagnusSpeychal
Jul 17th, 2007 at 8:24am
Hi
When deleting a box, any arrows between this box and other boxes are also deleted. If the "ArrowDeleted" event is handled I have noticed that one can still obtain information (Tag, UserString etc.) from the box which was deleted.
My question is thus, When is it no longer possible to obtain information about a deleted box and what can be done to it besides obtaining info?
Best regards,
Magnus
Re: Deleting boxes and arrows
Reply #1 - Jul 17th, 2007 at 10:02am
The box object is deleted immediately after raising the arrow events, and its memory is freed. It is not safe to keep a reference to that object and use it in any way afterwards.
MagnusSpeychal
Reply #2 - Jul 17th, 2007 at 10:25am
Hi Stoyan
If I understand you correctly, using the commands:
arrow.GetOriginBox();
arrow.GetDestinationBox();
in the "ArrowDeleted" event is a very bad idea! Am I right?
How about when deleting a box. Is it safe to use the "box" item in the "BoxDeleted" event?
Best regards,
Magnus
Reply #3 - Jul 17th, 2007 at 11:37am
Hi Magnus,
You should still be able to access the box and read its properties from the Deleted events. However keeping a reference to the box and using it after exiting from the event handlers is not safe. Creating links or groups related to the box being deleted is not a good idea either.
MagnusSpeychal
Reply #4 - Jul 17th, 2007 at 11:56am
Hi Stoyan
Thank you!
So the commands:
arrows.GetOriginBox();
arrows.GetDestinationBox();
are OK as long as they are used within the "ArrowDeleted" event?
Also:
I have two boxes connected by an arrow. When one box is deleted the other one should be deleted as well. First I put some code in the "BoxDeleted" event to do this using the arrow connecting the boxes. This did not work since when deleting a box, the code in the "ArrowDeleted" started executing directly so that when the code in "BoxDeleted" should execute the arrow was  not available!
Second I tried putting some code in the "RequestDeleteBox" event but this did not work either. This code included a for-loop but this only executed once and control never returned to this loop.
Any ideas?
Best regards,
Magnus
Reply #5 - Jul 17th, 2007 at 12:58pm
Hi Magnus,
Yes, that should work fine.
