Normal Topic Display error while setting header text (Read 2587 times)
trash2all
Jul 17th, 2007 at 8:33am
error displayed where sertting header's text on
apopoint in dayrange view,
image is attached.
also i have a question,
can i set the calendar so it will display header text only on timetable view and not on other view?
if so, please describe me how.
thanks in advance.
Re: Display error while setting header text
Reply #1 - Jul 17th, 2007 at 1:09pm
Unfortunately, you cannot control whether the header text is displayed or not, unless you use custom drawing. However, you can temporarily set empty headers while the items are displayed in a view, where you don't want their texts to be visible, and vice versa, set the texts back when you want them visible. You can use the Item's Tag property for temporary holder of the header text, while it is invisible.
As for the text being rendering incorrectly: Does it render this way in all views or only in the DayRange view? As far as I can see looking at the code, we are simply the DrawString(String, Font, Brush, RectangleF) method of the .NET Graphics class.
