Normal Topic Deleting objects from collections (Read 3159 times)
MagnusSpeychal
Jul 19th, 2007 at 8:03am
Hi
I have loaded a file with the "LoadFromFile" method. The file was created using the "SaveToFile" method.
After loading the file I obtain a collection of boxes using the "GetBoxes"() method. I iterate over these boxes using the "GetCount" and "GetItem" methods. For certain conditions I wish to delete a box. I then use the "DeleteItem" method with a parameter obtained from the "GetItem" method. This gives me an error:
Unhandled exception... Access violation reading location...
Any ideas why this happens? I have used the "DeleteItem" method before without any problems. Is the problem related to loading the file or obtaining objects with the "GetItem" method?
Best regards,
Magnus
Re: Deleting objects from collections
Reply #1 - Jul 19th, 2007 at 10:30am
Are you sure the exception is thrown by DeleteObject, and not by GetItem? Calling DeleteObject(box) removes the box from the Flowchart.Boxes collection, and that could lead to using a non-existing box index at some point in the loop.
MagnusSpeychal
Reply #2 - Jul 19th, 2007 at 11:59am
Hi Stoyan
Yes, the exception is thrown by DeleteObject. I suspected the GetItem method at first but it turned out that this is ok.
My code (for test purposes) looks something like this:
m_FlowChart.LoadFromFile(_T("test.sld"));
nodes=m_FlowChart.GetBoxes();
for(int i=0;i<nodes.GetCount();i++)
bi=nodes.GetItem(i);
m_FlowChart.DeleteItem(bi);
The exception is thrown on the first "round" in the loop.
After the GetItem method I use debugtools to check "bi" and all data seems correct.
Best regards,
Magnus
Reply #3 - Jul 19th, 2007 at 3:49pm
Is that code invoked from a handler of some FlowchartX event?
MagnusSpeychal
Reply #4 - Jul 20th, 2007 at 3:57am
Hi Stoyan
I found the problem. Seems I am the one to blame since I did not see problem all the way through.
I have a lot of code in the "BoxDeleted" event which I did not handle correctly.
I am very sorry for taking your time with this and I hope you have not spent to much time on it.
Best regards,
Magnus
