Normal Topic Distribution (Read 2372 times)
MagnusSpeychal
Distribution
Jul 23rd, 2007 at 8:34am
Hi
When I want to distribute an application that uses the FlowChartX-ActiveX control, what files do I have to distribute with the application and what settings are needed on the host computer?
Best regards,
Magnus
Re: Distribution
Reply #1 - Jul 23rd, 2007 at 10:24am
You need to distribute the flowchart.dll. Mark it as self-registering COM library in your installer software.
If you are using the GDI+ mode, you must also distribute the gdiplus.dll.
If using the XmlReader and XmlWriter classes, you must distribute the MSXML 4 runtime.
LarsL
Re: Distribution
Reply #2 - Jul 24th, 2007 at 8:24am
It works when I just distributed the DLL
and also   self-register it with my WISE installer software.
Thanks Stoyan.
/Lars and Magnus
