Normal Topic Arrow Routing (Read 2332 times)
koosala
Java Happens
Arrow Routing
Jul 30th, 2007 at 4:50am
I have the following code:
private void TestArrows() {
flowChart = new FlowChart();
this.getContentPane().add(flowChart);
flowChart.setMeasureUnit(GraphicsUnit.Pixel);
flowChart.setRouteArrows(false);
Box top = new Box(flowChart);
Box below1 = new Box(flowChart);
Box below2 = new Box(flowChart);
top.setObstacle(false);
below1.setObstacle(false);
below2.setObstacle(false);
below1.attachTo(top, AttachToNode.TopLeft);
below2.attachTo(top, AttachToNode.TopLeft);
top.setBounds(new Rectangle2D.Float(100, 100, 100, 100));
below1.setBounds(new Rectangle2D.Float(150, 250, 100, 100));
below2.setBounds(new Rectangle2D.Float(350, 250, 100, 100));
flowChart.add(top);
flowChart.add(below1);
flowChart.add(below2);
Arrow top1 = new Arrow(flowChart, top, below1);
Arrow top2 = new Arrow(flowChart, top, below2);
flowChart.add(top1);
flowChart.add(top2);
UpdateConnector(top, below1);
UpdateConnector(top, below2);
private void UpdateConnector(Box group, Box subordinate) {
// There will be only one connector
Arrow connector = subordinate.getIncomingArrows().get(0);
connector.getControlPoints().clear();
float midY = (subordinate.getBounds().y + group.getBounds().y + group.getBounds().height) / 2;
connector.getControlPoints().add(new Point2D.Float(group.getBounds().x + group.getBounds().width / 2, group.getBounds().y + group.getBounds().height));
connector.getControlPoints().add(new Point2D.Float(group.getBounds().x + group.getBounds().width / 2, midY));
connector.getControlPoints().add(new Point2D.Float(subordinate.getBounds().x + subordinate.getBounds().width / 2, midY));
connector.getControlPoints().add(new Point2D.Float(subordinate.getBounds().x + subordinate.getBounds().width / 2, subordinate.getBounds().y));
connector.setStyle(ArrowStyle.Cascading);
connector.updateFromPoints();
1. I have given the arrow a cascading feel and assigned 4 control points per arrow.
So, both arrows should appear with two bends, but when rendered, they come up with only 3 control points.
2. I can add the line flowChart.setArrowStyle(ArrowStyle.Cascading);
This will make the arrows come up with two bends. But on moving the top box, the second arrow loses its shape. How do I prevent this?
Praveen
Re: Arrow Routing
Reply #1 - Jul 30th, 2007 at 6:03am
1. Instead of clearing the control points collection and adding new points,  call setSegments(3) and then use the PointCollection.set() method to set the point coordinates.
2. If an arrow's segment does not keep strictly horizontal or vertical direction, probably you should call the Arrow.setCascadeOrientation() method to specify what direction you will be using, before calling setStyle().
