Normal Topic Appointment resizing (Read 4084 times)
MichaelH
Did you not get the memo?
Aug 6th, 2007 at 1:11pm
I believe I have found an issue with the Calendar when set to the timetable view.
If an appointment is placed at the very start of the calendar, and then selected, you are unable to resize the left hand side of the appointment.
If the appointment is de-selected, then the user can resize normally.
Is this a known problem?
Re: Appointment resizing
Reply #1 - Aug 7th, 2007 at 4:44am
It appears that the column headers are hit-tested before items. Therefore, when the item starting at the very beginning of a day is selected, its resize band is positioned completely above the headers and it cannot be hit-tested. We will check whether we can change the hit-testing order without causing any side effects.
Reply #2 - Aug 7th, 2007 at 5:14am
Here is an updated version:
https://mindfusion.org/_planner/_Planner.NET_422pre_trial2.zip
Please, check if the problem has been fixed.
MichaelH
Reply #3 - Aug 7th, 2007 at 6:30am
I'll take your word for it - I don't think I can use the updated control you posted as it is the trial version and when I try it out I get many errors when building the project (after updating the references).
I'll wait for the next release!
Michael.
