Hot Topic (More than 10 Replies) How do you add comments for Flow Charts? (Read 6083 times)
uv
Aug 7th, 2007 at 3:03am
Hi, Smiley
I need to know how i can add comments to a Node by simply right clicking it. Please let me know whether i have to import a libarary for this?
Thanks in Advance
Re: How do you add comments for Flow Charts?
Reply #1 - Aug 7th, 2007 at 5:44am
If you need to start editing the node's text upon right-click, handle the BoxClicked event and call the Box.BeginInplaceEdit method when e.Button == MouseButtons.Right.
uv
Reply #2 - Aug 7th, 2007 at 9:33pm
Thanks for the reply. But sorry that is not what i really wanted Sad. I need to add a COMMENT BOX or a NOTE to each node. e.g. like in Rational Rose, you can simply right click on a class diagram,and add a note to that.
Please help me with this. ???
Thanks again.
Reply #3 - Aug 8th, 2007 at 6:32am
Ok, create a box, attach it to the node, and optionally let users edit it inline:
Box commentBox = fc.CreateBox(...);
commentBox.AttachTo(classBox, AttachToNode...);
commentBox.BeginInplaceEdit();
Now the comment box will follow the class when the latter is moved around. If you have a class box reference, you will be able to access its comment boxes through the classBox.SubordinateGroup.
uv
Reply #4 - Aug 9th, 2007 at 12:23am
Thanks alot Roll Eyes. It helped me alot!
Kind Rgds,
UV
uv
Reply #5 - Aug 9th, 2007 at 2:13am
Hi Stoyo,
Need to ask one more question. Once I right click and add the comment box, is it possible to attach it(without any arrows) to the selected node by using +/- button, so from that i can expand and collapse the comment box?
here with i'm sending the code, pls help me with it :(
private void addCommentToolStripMenuItem_Click(object sender, EventArgs e)
Box commentBox = loader.Chart.CreateBox(SelectedNode.BoundingRect.Right, SelectedNode.BoundingRect.Top - 10, 20, 20);
commentBox.Style = BoxStyle.Rectangle;
commentBox.FillColor = Color.LightGoldenrodYellow;
commentBox.AttachTo(SelectedNode, AttachToNode.BottomRight);
SelectedNode.SubordinateGroup.AttachToCorner(commentBox, 0);
SelectedNode.Expandable = true;
Thanks in Advance!
Reply #6 - Aug 9th, 2007 at 8:23am
To use the +/- button without arrows, set the FlowChart.ExpandButtonAction property to RaiseEvents. Then from the ExpandButtonClicked event handler set commentBox.Visible to either true or false.
uv
Reply #7 - Aug 10th, 2007 at 1:31am
Thanks Stoyo! It works fine. Cheesy
cheers!
Reply #8 - Aug 10th, 2007 at 5:10am
uv
Reply #9 - Aug 13th, 2007 at 3:42am
Hi Stoyo,
Now i need to add a comment box, where ever i right clicked in the FlowChart. For this i have used the context menu event handler. But i need to get the current position (Point) of the location. Since we are not under a MouseEventArgs, i wont be able to get the mouse position. I have tried the following coding but it creates the box in a differnt place. Need ur help ASAP. Thanks !
PointF ptf = Chart.ClientToDoc(new Point(MousePosition.X,MousePosition.Y));
commentBox = loader.Chart.CreateBox(ptf.X, ptf.Y, 20, 20);
Reply #10 - Aug 13th, 2007 at 6:02am
MousePosition is in screen coordinates and you must convert it from screen to client coordinates and then from client to logical ones, e.g. Chart.ClientToDoc(Chart.PointToClient(MousePosition)).
Another option is to save in a PointF variable the mouse position you receive with the BoxClicked or DocClicked event, and then use it in the menu item handler.
uv
Reply #11 - Aug 13th, 2007 at 9:45pm
Thanks Stoyan! Roll Eyes
It works fine.
cheers!
