Normal Topic Color / Brush-Dialog (Read 1328 times)
shil
Aug 9th, 2007 at 12:13pm
Hi there, i have a question about the brushes.
If i use a flowchart object in vs 2005 i can select a
brush for boxes, arrows and so on. now i want these
littel dialog, where u can select a style and colors, in my program. Is there any assembly where i can get this dialog?
Re: Color / Brush-Dialog
Reply #1 - Aug 9th, 2007 at 1:01pm
That dialog is a property editor, associated with the Brush class using the Editor attribute. It seems the PropertyGrid control uses the following code to display property editors:
IUIService service = (IUIService) this.GetService(typeof(IUIService));
try
     if (service != null)
           service.ShowComponentEditor(objectToEdit, this);
I guess objectToEdit should be the Box.Brush. There is a lot more code there - so if the code above does not work, use the .NET Reflector tool to look at the PropertyGrid.OnViewButtonClickPP() method for other possible ways to display editors.
