Normal Topic printpreviewex (Read 2089 times)
shil
printpreviewex
Aug 10th, 2007 at 10:21am
hi, could it be that the printpreviewex dialog have some bugs?
if i move the dialog, i cant use the non client area any more.
Re: printpreviewex
Reply #1 - Aug 10th, 2007 at 12:30pm
Do you mean you can't draw on the flowchart anymore? The print preview is displayed as a modal dialog, so you must close it first before being able to interact with the flowchart again.
nejelski
Re: printpreviewex
Reply #2 - Apr 1st, 2010 at 8:29pm
I have a question about PreviewDiagram method of FlowChartPro .I need it to be modal, but it is not!Even if I test your samples .\Palette\MFC , it opens print preview as not Modal dialog!I could still click on original flowchart dialog? Any help?
Re: printpreviewex
Reply #3 - Apr 2nd, 2010 at 8:14am
Is this about the ActiveX control? Print preview there is shown inside a floating window and there isn't any way to show it as a modal dialog at this time.
If by chance you are using the control from a C program that runs the Windows message pump code, you could process only messages sent to the window identified by the WindowHandle property of the returned PrintPreview object.
If you simply want to disable drawing on the flowchart canvas while the preview window is shown, set the flowchart's Behavior to bhDoNothing, or enable its StaticMode property.
nejelski
Re: printpreviewex
Reply #4 - Apr 8th, 2010 at 7:34pm
Hi Stoyo,
Thanks for reply.
Yes, it is about ActiveX control. I thought I was doing something wrong. Too bad it is not modal.
Anyway, I have done what I wanted.
Thanks again.
Mikhail.
