Normal Topic How to ignore resolution of background image? (Read 3023 times)
Rennie
May 3rd, 2013 at 6:27am
When I specify a background image via Diagram.BackgroundImage, it is displayed according to the resolution (dpi) specified in the Image object. This may be 300dpi or 72dpi or something else - at the moment I'm just accepting the dpi specified in the user's .jpg or .png file.
Is there some way to get DiagramView's rendering to ignore the resolution and just display the image pixel-for-pixel?
Alternatively, what's the recommended way to modify the resolution settings in the Image object so it matches the screen resolution?
Rennie
Re: How to ignore resolution of background image?
Reply #1 - May 3rd, 2013 at 7:56am
You could draw an image using Graphics methods from DrawBackground event handler, instead of setting BackgroundImage. Don't use the Utilities.DrawImage method, because it does the resolution scaling you don't want.
Another way to achieve that could be setting the HorizontalResolution and VerticalResolution properties of the BackgroundImage to values corresponding to your screen resolution.
Rennie
Reply #2 - May 4th, 2013 at 12:38am
Thanks, I've gotten it to work using your first suggestion. Thanks for good support.
(Your second suggestion doesn't work - the HorizontalResolution and VerticalResolution properties do not have setters.)
Reply #3 - May 6th, 2013 at 5:51am
You can still change the resolution property values using the Bitmap.SetResolution method.
Rennie
Reply #4 - May 6th, 2013 at 11:16am
OK, I'm trying this now, and it seems to work:
using (Graphics graphicsObject = this.CreateGraphics())
   ((Bitmap)_diagramView.Diagram.BackgroundImage).SetResolution(graphicsObject.DpiX,
        graphicsObject.DpiY);
Is this what you meant? Is there a simpler way of doing it?
Reply #5 - May 6th, 2013 at 2:22pm
Yes; this looks simple enough Smiley
