Normal Topic Centered Zoom (Read 2646 times)
jsamba
Centered Zoom
Aug 17th, 2007 at 2:05pm
I want the user to be allowed to zoom using a slider control, the mousewheel or double-clicking inside the diagram.
I use ZoomFactor to perform the zoom/unzoom responding to an event BUT it is the upper left corner of the visible rect which is invariant and I want it to be the CENTER of the visible rect.
I could do it knowing the coordinates of the visible rectangle.
I did not find a way to get the visible rect coordinates. I can reach to the left and top coord with ScrollY and ScrollY, that's all ... ???
Re: Centered Zoom
Reply #1 - Aug 18th, 2007 at 10:14am
If you know the size of the flowchart control in pixels, use the ClientPtToDocPt method to find the document coordinates of the lower-right corner.
jsamba
Re: Centered Zoom
Reply #2 - Aug 18th, 2007 at 2:09pm
Thank you Stoyan; I actually found a piece of code from you that does the work at
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcx_disc;action=display;num=115192...
jsamba
Re: Centered Zoom
Reply #3 - Aug 18th, 2007 at 2:11pm
... but it would be great to have it implemented as it is very useful
Something like the Scale, scaleX and ScaleY, scaleWidth ... fct et prop from VB  Wink
