Normal Topic UndoManager in 5.0 beta (Read 2533 times)
Alex
Aug 27th, 2007 at 5:24am
I recently upgraded our project to the 5.0 beta version. But now I have a problem with the Undomanager:
If I add an item from the ShapeList with Drag&Drop, i got 2 commands in the UndoManager.History before NodeCreated is raised.
The first command is a ModifyItemCmd, the second is a AddItemCmd.
After that, several other commands can be added without problems, but if I try to undo all (until NextUndo == null), I got a null reference exception on the first cmd in the history (which is the ModifyItemCmd).
I don't know if there is a bug or if I just do this wrong. It seems to me that undoing the AddItemCmd deletes the object and the ModifyItemCmd then has a null reference.
Any ideas with that problem?
Best regards,
Alex
Re: UndoManager in 5.0 beta
Reply #1 - Aug 27th, 2007 at 8:43am
That's a bug. We'll upload a fixed beta version tomorrow.
Reply #2 - Aug 28th, 2007 at 11:05am
This version should work better:
https://mindfusion.eu/FCNetBeta.zip
Alex
Reply #3 - Aug 29th, 2007 at 6:17am
Yes, works perfectly!
