Normal Topic AnchorPattern not marked as [Serializable] (Read 2123 times)
Dimitry
Aug 28th, 2007 at 10:49am
I need store instances of AnchorPattern in DB. I have written simple code
[Serializable]
public class ShapeStencil
private AnchorPattern _anchorPattern;
And received exception in runtime.
I see class implemented IPersists. But this interface is internal.
How can i store AnchorPattern class?
Re: AnchorPattern not marked as [Serializable]
Reply #1 - Aug 28th, 2007 at 11:37am
You will have to implement the serialization yourself, e.g. by implementing the ISerializable interface and (de)serializing the AnchorPattern members inside the ShapeStencil's GetObjectData method and constructor.
Dimitry
Reply #2 - Aug 28th, 2007 at 12:06pm
But AnchorPattern contains AnchorPointCollection and AnchorPoint. And this classes also non serializable.
If i will use your solution i have to write next
[Serializable]
  private List<AnchorPointEx> _anchorPattern;
  private static AnchorPattern ListToPattern(List<AnchorPointEx> list)
  private static List<AnchorPointEx> PatternToList(AnchorPattern list)
[Serializable]
class AnchorPointEx
  public AnchorPointEx(AnchorPoint point)
    // Copy all properties
  // This class contains all properties as AnchorPoint
  // because AnchorPoint is sealed
I think i will make a lot of overhead work. I see two decisions:
  • Classes AnchorPattern, AnchorPointCollection and AnchorPoint mark as Serializable
  • To make AnchorPoint class as non sealed
What do you think?
Reply #3 - Aug 28th, 2007 at 1:30pm
Ok, we can make these classes serializable, but not before we release version 5.
jmquinlan
Reply #4 - Apr 2nd, 2009 at 8:37am
As far as I can tell the layout classes are not marked as serialisable, is there a way around this similar to the above or is it something that you guys can fix for the next release?
The problem i have is providing customisable support for the layout parameters, without having the classes as serialisable it makes saving those layout parameters for each layout type an incredible pain in the arse..
Any help would be appreciative?
