Normal Topic How to remove all arrows ? (Read 2953 times)
isteele
Aug 30th, 2007 at 3:11pm
This might seem like an odd question, but how can I programmatically remove all the existing arrows in a chart ?
I tried calling fc.Arrows.Clear(), but even though the Arrows.count value was set to zero the arrows were still displayed even after calling Refresh().
Furthermore, if I subsequently tried to manually remove one of the arrows after calling the Clear() method the following Argument Exception was thrown
"Cannot remove the specified item because it was not found in the specified Collection."
Thanks in advance,
Ian.
Re: How to remove all arrows ?
Reply #1 - Aug 30th, 2007 at 3:17pm
You should delete the arrows one by one:
while (fc.Arrows.Count > 0)
  fc.DeleteObject(fc.Arrows[0]);
Calling diagram.Links.Clear() should work fine in version 5 of the control.
isteele
Reply #2 - Aug 30th, 2007 at 3:34pm
Hi Stoyan,
Thanks for the quick reply!
I tried the code you suggested but it went into an invariant state as Arrows.count was decremented once, but never decremented thereafter (seems like the Arrows collection is a little bit buggy - looking forwards to V5!).
I got around the problem but using a local variable set to the initial Arrows.count value and decrementing it and it all worked fine:
           int aa = fc.Arrows.Count;
           while (aa > 0)
               aa--;
Best regards,
Ian.
isteele
Reply #3 - Aug 30th, 2007 at 3:55pm
Hi again,
I said previously that it was now working - my mistake, it isn't! Smiley
Even after using a local variable as a count when removing arrows the Arrow.count is still non-zero.
In the test I am using the Arrow.count value is set to 7 immediately after the while loop (initially it was 10), example...
           int aa = fc.Arrows.Count;  // aa == 10
           while (aa > 0)
               aa--;
           aa = fc.Arrows.Count;  // aa = 7
Interestingly when the diagram is displayed there are in fact *4* arrows displayed.  I verified that there were no overlayed arrows by manually deleting them (without any exceptions this time though!).
Something very odd is happening here.
Can you suggest anything ?
Best regards,
Ian.
Reply #4 - Aug 30th, 2007 at 4:05pm
For some reason some arrows might be referenced more than once from the collection. Check if you are not calling Add and adding an arrow more than once? Or by some chance adding new arrows from the ArrowDeleted event?
isteele
Reply #5 - Aug 30th, 2007 at 4:14pm
Hi yet again,
I really have solved the problem this time!...
I was adding the arrows using fc.CreateArrow(), but there was an old bit of code that was also adding the arrows directly to the collection using fc.Arrows.Add().  Removed the latter call and all works swimmingly now!
Thanks for you help, Stoyan.
Best regards,
Ian.
