Normal Topic ScrollTo center box (Read 1820 times)
asloan
ScrollTo center box
Sep 4th, 2007 at 3:32pm
I am working on a search function that will allow a user to search a diagram for a box containing text that they specify.
Once the box is found, I want to center that box in the FCX control.  What is the best way to go about that?
Alan Sloan
Re: ScrollTo center box
Reply #1 - Sep 4th, 2007 at 3:53pm
BringIntoView should center the specified box in the control, as long as it's not visible in the current view. So you might try to scroll far from the box to make sure it's not visible, and then call BringIntoView to center on it.
