Normal Topic Custom Print Preview (Read 1285 times)
Achus
Sep 6th, 2007 at 2:59am
Hi I’m trying to show a print preview of flowchart in an internal tab window.
PrintPreview(), PrintPreviewEx() makes a model popup but this is not what I need.
I need to show the preview using a System.Windows.Forms.PrintPreviewControl.
I tried the following:
Used FlowChart.CreateImage() to create a Bitmap
and use this image to do graphics.DrawImage() inside the PrintDocument.PrintPage
This works but the resolution of the preview/print is not good enough. The built in PrintPreview/Print function makes far better print.
I am assuming this is because the limitation of Bitmap image opposed to vector graphics?
Is there a way get around the problem ???
Thanks in advance Kiss
Re: Custom Print Preview
Reply #1 - Sep 6th, 2007 at 6:37am
That might be possible using the PrintPreviewEx(Form previewForm) overloaded method. Take a look at how it is implemented:
public void PrintPreviewEx(Form previewForm)
	// setup the .NET print document
	PrintDocument doc = new PrintDocument();
	doc.DocumentName = printOptions.DocumentName;
	doc.DefaultPageSettings.Margins = printOptions.Margins;
	printDoc = doc;
	doc.BeginPrint += new PrintEventHandler(BeginPrint);
	doc.PrintPage += new PrintPageEventHandler(PrintPage);
	if (previewForm is IPrintPreview)
		(previewForm as IPrintPreview).Document = doc;
	previewForm.ShowDialog(this);
	doc.PrintPage -= new PrintPageEventHandler(PrintPage);
	doc.BeginPrint -= new PrintEventHandler(BeginPrint);
You must create a new form that implements IPrintPreview, and whose Document property sets the PrintDocument of the PrintPreviewControl from your tab window. FlowChart.NET will automatically open the form by calling its ShowDialog method, so you will need to close it, e.g. by calling Close from the OnLoad event handler.
I haven't tried if that works. If it doesn't, we could add a new PrintPreview overload that takes a PrintPreviewControl as an argument.
