Normal Topic Error in Flowchart.NET 5  Help file (Read 3234 times)
Samun
Sep 7th, 2007 at 10:11pm
Hello, I just found an inconsistency in the Flowchart.NET 5 Help file for the "SaveToString" method:
I.a.w. the help file, the method can be used as follows:
string SaveToString ();
string SaveToString (bool clearDirty);
Unfortunately, in the Flowchart.NET 5 API the real method (in VB.NET) is as follows:
SaveToString () as string;
SaveToString (format as Mindfusion.Diagramming.Savetostringformat, clearDirty as boolean) as string;
I'd like to know what the Savetostringformat is, perhaps it is useful but I canīt find it in the Help file...
Re: Error in Flowchart.NET 5  Help file
Reply #1 - Sep 10th, 2007 at 6:52am
You can use the following SaveToStringFormat values:
Base16
Base64
Xml
CompressedXml
Base16 and Base64 specify binary serialization. They correspond to what you could set via the FlowChart.SerializationOptions property in version 4. Base16 encodes each byte using two ASCII characters in the range [0-9,A-F], which was the only supported format in versions older than 4. Base64 encodes each 3 bytes using 4 ASCII characters. That was the default in versions 4.*
Xml and CompressedXml correspond to what you'd get using the XmlWriter.WriteToString(bool compressed) method.
sarada
Reply #2 - Oct 21st, 2008 at 8:55am
what does this mean base16 xml and all actually whats the purpose of this savetostring property whether it stores diagram view's flow chart infoemation or not plz tell me how to get the diagram's info in string format its urgent.
thank u in advance..........
Reply #3 - Oct 21st, 2008 at 10:08am
If you want to get a human-readable string, you might use diagram.SaveToString(SaveToStringFormat.Xml). The rest of them encode the diagram information in a more compact format that you might use to store the diagram in a database for example.
