Normal Topic BoxClicked Event (Read 2688 times)
alesdario
BoxClicked Event
Sep 12th, 2007 at 7:11am
Hi stoyo.
In WebChart.NET.dll BoxClicked Event can be used like in FlowChart.NET.dll?
this code does'n generate anything. Sad
private void Page_Load(object sender, System.EventArgs e)
fc.BoxClicked += new BoxMouseEvent(fc_BoxClicked);
private void fc_BoxClicked(object sender, BoxMouseArgs e)
   fc.ClearAll();
Tanks
Re: BoxClicked Event
Reply #1 - Sep 12th, 2007 at 8:24am
The WebChart.NET.dll does not support events. You could pass some arguments through the Box.HyperLink that will let you find out on the server side which box has been clicked. You can also use hyperlinks of the form "javascript: code" to handle that on the client side.
alesdario
Reply #2 - Sep 12th, 2007 at 8:27am
Stoyo wrote on Sep 12th, 2007 at 8:24am:
You can also use hyperlinks of the form "javascript: code" to handle that on the client side...
I do this but when i click on a box, first is opened a web page, and after is opened javascript. Why? Is it normal?
Very very tanks.
Reply #3 - Sep 12th, 2007 at 8:47am
Set HtmlBuilder.LinkTarget to "_self" and then the browser shouldn't open a new window.
alesdario
Reply #4 - Sep 12th, 2007 at 10:39am
Excese me stoyo...where i must insert the code you write me? Smiley
Reply #5 - Sep 12th, 2007 at 12:06pm
Aren't you using HtmlBuilder somewhere in your code to enable hyperlinks for the exported flowchart image? There just before calling the CreateImageMap method, set the LinkTarget property to "_self".
alesdario
Reply #6 - Sep 12th, 2007 at 12:57pm
Sorry   Smiley Smiley Smiley Smiley Smiley Smiley I dismiss from the mind... Smiley
Tanks!
