Version 1.2.2 of JDiagram contains the following improvements:
~ wrapping text to new lines can be disabled, clipping the text if it overflows
~ now text can wrap to a new line at arbitrary position in the text
~ ScriptHelper.loadShapeLibrary lets you load a custom shape library from JavaScript
~ ScriptHelper.createTextFormat lets you create TextFormat objects from JavaScript
~ FlowChartApplet.createFlowChart can be overridden to return an object derived from FlowChart
~ the OverviewApplet class implement an applet that wraps the Overview control
~ BehaviorType.Pan enables panning without using the Alt key
~ the ENTER and ESC keys can be used to accept or cancel inplace editing
~ now the itemModified event lets you find out the selection handle used to modify an item
~ the nodesIntersect method lets you find out if two nodes are overlapping
~ the cancelDrag method of ValidationEvent lets you immediately cancel the operation
An evaluation version is available for download here:
https://mindfusion.eu/JDiagramTrial.zip
Registered customers are going to receive their upgrades shortly.
