Normal Topic Anchor point tool tips (Read 1508 times)
srlevitt
Sep 28th, 2007 at 1:00pm
I have two blocks, each with anchor points on them. The anchor points have tool stips set which display OK when I just hover over them. I then try to create an arrow from a point on one block to a point on the second block. Whilst the arrow is being created, is there a way to get the destination anchor point to display it's tool tip as the mouse hovers over?
Re: Anchor point tool tips
Reply #1 - Sep 28th, 2007 at 1:07pm
You can get the destination anchor point by handling the LinkCreating event and checking the AnchorIndex event argument. You might have to use your own ToolTipControl to display the tooltip.
srlevitt
Reply #2 - Sep 29th, 2007 at 4:35pm
Yes, that seems to work. Thanks.
