Normal Topic data binding (Read 1826 times)
fabiogiustini
data binding
Oct 1st, 2007 at 10:32am
I need to bound calendar data into database: is there a db schema of the calendar's objects?
Fabio
Re: data binding
Reply #1 - Oct 1st, 2007 at 12:16pm
Planner.NET supports databinding only in its build for the .NET Framework 2.0. As for the schema, there is a Planner.mdb file in the Samples/DataBinding directory where you have installed Planner.NET on your machine. You can also perform various mappings between fields in your database and the properties of the Planner.NET objects. For more information on databinding, check Tutorial #9 in the accompanying documentation.
fabiogiustini
Re: data binding
Reply #2 - Oct 3rd, 2007 at 5:50am
Ok, thanks a lot!!!! Grin
