Normal Topic Symmetric (Read 4368 times)
asloan
Symmetric
Oct 2nd, 2007 at 4:49pm
How come whenever I use the Symmetric=True property on a TreeLayout I always get this error?
Automation error
The object invoked has disconnected from its clients.
Even happens in the FCX Sample Apps(such as Layouts.vbp)
Alan
Re: Symmetric
Reply #1 - Oct 3rd, 2007 at 1:47am
It works fine for me. Could you email me the saved flowchart and your TreeLayout property values with which you are getting that error?
asloan
Re: Symmetric
Reply #2 - Oct 3rd, 2007 at 3:55pm
Running the VB "Layouts" project from the Sample applications installed with FXC will produce the error.
If I run the project, Select any of the layouts from the left menu strip, and try to apply any kind of layout while using the "Symmetric" option at the top it will produce the following error.
Run-time error '-2147417848(80010108)':
Method 'ArrangeDiagram' of object 'IFlowChart' failed.
Alan
Re: Symmetric
Reply #3 - Oct 3rd, 2007 at 5:07pm
It still works fine here. What version of the control are you using?
asloan
Re: Symmetric
Reply #4 - Oct 3rd, 2007 at 5:15pm
Re: Symmetric
Reply #5 - Oct 4th, 2007 at 7:48am
I have sent you a flowchart.dll that should work better. Open the private messages area from the link at the top of this page to find it.
asloan
Re: Symmetric
Reply #6 - Oct 4th, 2007 at 2:48pm
Thanks, that seemed to fix the error, however it has had severe negative effects on the layout of my diagrams.
I think I can do without the Symmetric property, although it would be nice.
Alan
Re: Symmetric
Reply #7 - Oct 4th, 2007 at 5:20pm
Symmetric places half the root's children at one side of the root, and the other half at the opposite side. The first branch of the tree grows in the TreeLayout.Direction, and the other branch in the opposite direction. If your code relies on the TreeLayout using the same direction for all children, you might have to modify it to accommodate for the two directions being used with the Symmetric option.
