Normal Topic Changing shapetemplate (Read 1717 times)
MagnusSpeychal
Oct 3rd, 2007 at 9:17am
Hi!
I have noticed that when the shapetemplate of an object is changed, the anchorpattern is reset and incoming and outgoing arrows are affected as well due to the reset anchorpattern.
Is this correct? and is it possible to override this?
In my application I have to set the correct anchorpattern and reposition all arrows after changing the shapetemplate and this requiers an extra effort.
Best regards,
Magnus
Re: Changing shapetemplate
Reply #1 - Oct 3rd, 2007 at 10:23am
The ShapeTemplate's AnchorPattern is assigned to a box when you set the box' Shape. You might try assigning the box.AnchorPattern to the ShapeTemplate before setting the box.Shape, but I am note sure if this will work.
