Normal Topic No method like SetCellFont? (Read 2663 times)
rcruzmar
Oct 6th, 2007 at 12:58am
Just looking for a confirmation on this or have you point me in the right direction. Wink Is it correct that there is no method available to set or change the font for a given Table Cell? If there is it is not quite obvious to me. Undecided
If there is not such method, could you please add it as a suggestion for the next release of the FlowChartX? Grin
Thanks.
Rolando
Re: No method like SetCellFont?
Reply #1 - Oct 6th, 2007 at 9:48am
I can see a CellFont indexed property in the control's IDL, and there are
OleFont TableItem::GetCellFont(long col, long row);
void TableItem::SetCellFont(long col, long row, LPDISPATCH newValue);
methods in the TableItem.h wrapper class definition. The CellFont property was introduced in FlowChartX 4.1.2, in case you are using an older version.
rcruzmar
Reply #2 - Oct 6th, 2007 at 12:37pm
You are right, I have an older version of the FlowChartX so I purchased the upgrade. 8)
Thanks.
Rolando
Reply #3 - Oct 6th, 2007 at 12:58pm
Thanks 8) I have just emailed you the download link.
