Normal Topic Custom Draw (Read 1850 times)
fabiogiustini
Custom Draw
Oct 11th, 2007 at 4:39pm
i need to view a little icona near each resource header in resource view calendar.
How can i achieve that? Whit custom draw? Could anyone show me the example vb.net code?
thank you
Fabio
Re: Custom Draw
Reply #1 - Oct 12th, 2007 at 4:34am
You need to set the Calendar.CustomDraw property to CustomDrawElement.ResourceViewItem then handle the Calendar.Draw event. The following code illustrates the code of a sample event handler:
Private Sub Calendar1_Draw(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.CustomDrawArgs) Handles Calendar1.Draw
    If e.Element = MindFusion.Scheduling.WinForms.CustomDrawElements.ResourceViewItem Then
	  e.Graphics.DrawImage(image, e.Bounds.X + 2, e.Bounds.Y + 2)
    End If
End Sub
The image variable above represents a valid .NET Image.
