Normal Topic SetWrapAtCharacter text spilling out sometimes (Read 4349 times)
koosala
Java Happens
Oct 15th, 2007 at 8:42am
I have this piece of code:
private FlowChart flowChart;
private void testTextWrap() {
flowChart = new FlowChart();
TextFormat test = new TextFormat(Align.Center, Align.Center);
test.setWrapAtCharacter(true);
flowChart.setTextFormat(test);
flowChart.setAllowInplaceEdit(true);
this.getContentPane().add(flowChart);
I create a box on the canvas.
Double click to start in-place edit.
Type one character.
Type lot of white spaces so that the cursor goes out of scope in the text area.
Then type some more characters.
Click on the canvas to set the text for the box. I observed that the text spills to the left side of the box, even though I mentioned that the text must wrap at character.
Praveen
Re: SetWrapAtCharacter text spilling out sometimes
Reply #1 - Oct 16th, 2007 at 11:57am
It seems too many spaces confuse the text layout function. We'll try to fix this in the next release. To work around this, remove repeating spaces from the text entered by the user in response to the BoxTextEdited event.
koosala
Java Happens
Reply #2 - Jan 28th, 2008 at 2:03am
Hi Stoyan,
Does the release 1.0.2 have this fix?
Praveen
Reply #3 - Jan 28th, 2008 at 6:03am
Hi Praveen,
We haven't fixed that yet.
koosala
Java Happens
Reply #4 - Jan 28th, 2008 at 6:07am
Hi Stoyan,
Do you think this would be possible anytime soon, or is there something I can do to get around this?
Praveen
Reply #5 - Jan 28th, 2008 at 11:53am
Hi Praveen,
Our developer will try to fix this later this week. For now you can replace repeating spaces with a single character.
Reply #6 - Jan 31st, 2008 at 6:35am
I have sent you a PM with an updated TextLayout.java. Let me know if you still have any problems.
koosala
Java Happens
Reply #7 - Jan 31st, 2008 at 7:11am
Works fine. Thank you!
Praveen
