Normal Topic relationship between appointment and contact (Read 3991 times)
elpuerco
Time?  What's time matta
to a pig?
Oct 17th, 2007 at 7:59am
I have a timetable view calendar and can add an appointment and save it to a database without any problems.
I have modified on the fly the AppointmentForm to show a new textbox and a button which will allow the user to save a contact against the current appointment.
I can save the appointment which is created in the drag_drop event as a local variable to that event without problem.
I can create a contact via my custom button on the AppointmentForm and save it.
However the two are not linked?
I look in my database and I see the appointment in the Item table and the contact in the Contact table but nothing in the ItemContact table which I believe links the two?
Here is the contact creation code:
Private Sub EditContact(ByVal sender As System.Object, ByVal e As System.EventArgs)
	  Dim frm As ContactDialog = New ContactDialog
	  frm.ShowDialog()
	  If frm.DialogResult = Windows.Forms.DialogResult.OK Then
		Dim c As Contact = New Contact
		c.FirstName = frm.txtCarrier.Text
		c.LastName = frm.txtContact.Text
		c.Phone = frm.txtTelephone.Text
		c.Email = frm.txtEmail.Text
		Me.calTimeTableView.Schedule.Contacts.Add(c)
	  End If
End Sub
How do I find the required appointment in the Calendar to asscociate the newly created (or to be edited) contact?
Thnx
Re: relationship between appointment and contact
Reply #1 - Oct 17th, 2007 at 8:43am
To establish a relationship between an item and a contact in the schedule, you have to add a reference to the contact to the item's Contacts collection.
You can obtain a reference to the item being edited in the AppointmentForm through its Appointment property.
Hope this helps.
elpuerco
to a pig?
Reply #2 - Oct 17th, 2007 at 9:34am
KOOL Wink
I have managed to link the two but have the added problem now that the ItemContact table does not remove the existing entry and just keeps adding a new row?
Here is my code, the item and contact table seem to be doing as I expect, any pointers???
Thnx
	  ' create the contact entry form
	  ' required objects and variables
	  Dim a As Appointment
	  Dim app As Appointment = New Appointment
	  Dim x As Boolean = False
	  ' save the id of the selected appointment so we can asscociate the contact
	  For Each a In Me.calTimeTableView.Schedule.Items
		If a.Id = strAppID Then
		    app = a
		    Exit For
		End If
	  Next
	  ' if count > 0 then set the fields on the contact detail form the exisitng data
	  ' note we will restrict this appplication to only 1 contact per appointment, no groups
	  If app.Contacts.Count > 0 Then
		c = app.Contacts.Item(0)
		frm.txtCarrier.Text = c.FirstName
		frm.txtContact.Text = c.LastName
		frm.txtTelephone.Text = c.Phone
		frm.txtEmail.Text = c.Email
		x = True
	  End If
	  ' display contact detail form to user
	  frm.ShowDialog()
	  ' if we get an ok save the changes
		If x = False Then
		    app.Contacts.Add(c)
		End If
	  End If
 End Sub
Reply #3 - Oct 18th, 2007 at 6:47am
Are you using the SQL built-in relationships between the tables in your database? If that is the case, remove all relationships between the tables. Planner.NET will take care of them internally. Otherwise SQL might prevent deleting records in one of the databases if there is a relation between dependent records.
elpuerco
to a pig?
Reply #4 - Oct 18th, 2007 at 1:37pm
Hi,  I have been into the designer and removed all relationships lines and the itemcontacts table still keeps adding new lines and not updating or removing the old ones?
Reply #5 - Oct 19th, 2007 at 7:06am
Is it possible to send me your database with the records within it?
Thank you,
elpuerco
to a pig?
Reply #6 - Oct 19th, 2007 at 8:31am
sure, can you give me an email address as I don't know how to attach a file here?
Thnx
Reply #7 - Oct 19th, 2007 at 10:53am
You can send it to support@mindfusion.eu.
Thank you,
