Normal Topic LoadFromString NullReferenceException (Read 2509 times)
Alex
Oct 19th, 2007 at 8:52am
I encounter the following problem:
I save a diagram with the SaveToString() method as a XML string.
The I try to load the XML string again with the LoadFromString method, but I always get a NullreferenceException within the call of LoadFromString.
Any ideas?
Best regards,
Alex
Re: LoadFromString NullReferenceException
Reply #1 - Oct 19th, 2007 at 9:04am
Could you set a breakpoint at the LoadFromString line and see if the string argument is not null be some chance?
Where are you storing the result returned from SaveToString()? LoadFromString might fail if the XML special symbols have been replaced with some escape sequences, e.g. if you are escaping them when saving the string somewhere, but not un-escaping them when loading?
Alex
Reply #2 - Oct 19th, 2007 at 9:15am
The string is not empty and it is stored in an object oriented database, db4o as String. This should not alter the String at all.
I changed it to SaveToString() without any parameters and it works correctly so far.
I keep trying, maybe I can narrow it down to some point.
Reply #3 - Oct 19th, 2007 at 9:28am
What happens if you run the following?
diagram.LoadFromString(diagram.SaveToString(StringFormat.XML))
Alex
Reply #4 - Oct 19th, 2007 at 9:37am
I try that later. Keep you posted!
Alex
Reply #5 - Oct 20th, 2007 at 7:19am
Ok, one thing I found out:
If I set the cleardirty flag to true, the LoadFromString method has a null reference. If I set the flag to false, I can load the diagram from the generated XML string.
But not all of the diagram properties are read from the string I think, because there is still a major difference between the behavior if I load the diagram from an normal string than from the XMl string.
Reply #6 - Oct 20th, 2007 at 9:06am
Are you handling the DirtyChanged event, and perhaps doing some changes to the diagram from the handler? Could you send the strings generated with and without using clearDirty to our support email address?
