Normal Topic Exporting/emailing schedule (Read 3518 times)
dimmer
Oct 25th, 2007 at 12:57pm
Hi
I have a requirement to email a copy of a schedule to various users outside our organization.  I noticed in the General Information section of the Guide under Output that it's apparently possible to 'Export parts or whole calendars as images', but am having trouble figuring this out.
Would you be able to point me in the right direction or suggest an alternative way  (I noticed in some previous posts that you had mentioned that you may add support to export to Excel)
Re: Exporting/emailing schedule
Reply #1 - Oct 25th, 2007 at 4:09pm
Call the Calendar.CreateImage method to get an image of the calendar, and then the Image.Save method to save it as an image file.
Excel support won't be available soon. We can easily add PDF support to the Report class if that will do for you.
dimmer
Reply #2 - Oct 25th, 2007 at 5:36pm
Creating the image works okay.  I've saved it as a .jpg and then attached it to the email.
However, I'm trying to create a report now to see how it looks and keep getting a blank page.  I have populated the calendar on a form from a database, and now am trying to create a report for the month from a button on the same form...
Dim rep as Report
With rep
.schedule = Me.calendar.schedule
.preview = ("1/10/2007", "31/10/2007")
End With
Thanks for any suggestions
Reply #3 - Oct 26th, 2007 at 5:02am
You have to insert the columns you would like to have in your report. For example, the following code prints a report with two columns, containing the header text and start date of the items respectively. The width ratio of the columns is set to 5:2.
Dim c As ReportColumn = r.CreateColumn()
c.Property = "HeaderText"
c.Width = 5
r.Columns.Add(c)
c = r.CreateColumn()
c.Property = "StartTime"
c.Width = 2
r.Columns.Add(c)
Also make sure that Options.AbsoluteColumnWidth is set to False.
dimmer
Reply #4 - Oct 26th, 2007 at 11:05am
Aaaah, okay, thanks for showing me.  One more question...
Is it possible to capture and export the images that are created after calling the calendar.printpreview method?
I have already set the Scale that I need for the different views depeding on the user's screen resolution, and then I call calendar.printpreview to view the pages.  I might want to export these images rather than using the CreateImage method if it's possible.
Thanks again for the help
Reply #5 - Oct 26th, 2007 at 12:23pm
Unfortunately I can't think of a way to do this. You may use one of the CreateImage overloads that accepts a scaling factor as argument.
dimmer
Reply #6 - Oct 26th, 2007 at 1:22pm
Okay thanks Meppy.
