Normal Topic ASP ProcessRequestInternal Error (Read 2925 times)
oakenshield
Oct 29th, 2007 at 11:40am
I use NetDiagram in an ASP project, and i've found in the logs of the application the following non-blocking error :
GLOBAL ERROR - The file does not exist.
at System.Web.StaticFileHandler.ProcessRequestInternal(HttpContext context)
This error is apparently caused by the diagram component, despite the fact that it is displayed correctly, so I'm wondering what is the exact cause of this error, any idea ?
Thanks in advance.
Re: ASP ProcessRequestInternal Error
Reply #1 - Oct 29th, 2007 at 12:31pm
StaticFileHandler is used by ASP.NET to send to the browser static files, as they are, without compiling or executing them. The only such file that might be requested while you are using NetDiagram is the applet's ".jar" file. Is there any file name mentioned in the logs regarding that error?
oakenshield
Reply #2 - Mar 31st, 2008 at 10:03am
I've refocused recently on that weird problem, here's what I found :
In debug mode, I watched the following object :
((HttpApplication)sender).Context.Request
The CurrentExecutionFilePath property of this object is :
<location of my ASP page>/META-INF/services/javax.xml.parsers.DocumentBuilderFactory
This directory doesn't exist, this could explain the "file does not exist" error !
I've tried to create manually this directory, after that the applet returned the following javascript error :
java.lang.Exception javax.xml.parsers.FactoryConfigurationError:
Provider <html> not found
Can you help me with this new elements ? This "file does not exist" error occurs very often...
Thanks !
Reply #3 - Mar 31st, 2008 at 11:14am
This class is used by the applet, and apparently the Java runtime tries to get it from the server before loading it from the local system. I suppose you could add to JDiagram.jar the DocumentBuilderFactory.class, but then there might be a lot more JDK classes needed. So if the problem is only the message appearing in the logs, probably it's best to not bother with it.
