Normal Topic "slipping" table row anchor problem (Read 2583 times)
hoffmandev
Oct 29th, 2007 at 1:44pm
I am evaluating your FlowChart.NET product. I am currently experimenting with a sample application your provided (via download). The project I am working in is:
C:\Program Files\MindFusion\FlowChart.NET Trial Version\VS2005 (.NET 2.0)\Samples\C#\ClassDiagram
I have modified this project with the following code changes:
In MainForm.cs in "private TreeNode AddTypeWithContents(TreeNode parent, Type type) { ... }" I have modified it to include an additional column with anchors for methods:
[code]
if (!method.IsStatic)
   //changed: commented out
   //table[col, row].ColumnSpan = 2;
//code added:
table.Columns[col].Width = 28;
table[0, row].Image = _pureImages[methodIcon]; table[0, row].ImageAlign = ImageAlign.Center;
table[col, row].Text = methodName;
table[col, row].ToolTip = methodName;
table[col, row].Tag = 0;
//code added:
AnchorPoint ptinout = new AnchorPoint(50, 50, true, true, Color.Red, col + 1);
ArrayList al = new ArrayList();
table[col+1, row].ImageAlign = ImageAlign.Center;
table[col+1, row].Image = _generalImageList.Images[0];
al.Add(ptinout.Clone());
table.Rows[row].AnchorPattern = new AnchorPattern((AnchorPoint[])al.ToArray(typeof(AnchorPoint)));
//end code added
[/code]
This code has allowed me to have anchors on all methods. This is exactly what I want! However, I have seen a problem. The problem is when I draw a line from one anchor on "Table A, Row X" to another anchor in a different,  "Table B, Row X" then it does not stick. After the link is drawn the Origin anchor "slips" and attaches itself to Row 1 (or some other row).
Please let me know if you would like me to email you the entire MainForm.cs. listing (along with my changes). I can also send you a drawing of the issue as well.
Re: "slipping" table row anchor problem
Reply #1 - Oct 29th, 2007 at 2:56pm
FlowChart.NET 5.0 had a bug related to anchor points and table rows. It should be fixed in version 5.0.1, which we released last week. If you are using V5.0, please try the new version:
https://mindfusion.eu/FCNetDemo.zip
Otherwise, please send your .cs file to our support email address.
Thank you,
hoffmandev
Reply #2 - Oct 29th, 2007 at 4:02pm
Problem solved.
Thank You
