Normal Topic Suggested Iterations (Read 1874 times)
mattref
Oct 30th, 2007 at 1:09pm
Hello Stoyan,
When generating our FlowchartX diagrams, we have determined that it would be beneficial to dynamically set the number of iterations our SpringLayout will be subject to. Is there a particular formula suggested by Mindfusion that we can use to calculate the necessary number of iterations for any given diagram? At the moment we're being pretty generous with the iterations - and we're gathering some basic information about the diagram nodes in deciding the amount of iterations.
Thanks in advance.
Re: Suggested Iterations
Reply #1 - Oct 30th, 2007 at 7:03pm
I guess you might use a number of iterations proportional to the number of nodes in the flowchart (or its square). However we haven't tried finding such formula and can't recommend you any particular nodes-to-iterations ratio.
