Normal Topic Modifying Table in PropertyGrid causes crash (Read 3028 times)
rfuegen
Oct 31st, 2007 at 2:45pm
when removing rows from a table, the flowchart control crashes with an Index out of range Exception.
how to reproduce this error with the flowchart.net demo application (version 4.3.1):
- select "Table-related diagrams"
- select the "ERM Diagram"
- click on (select) "Entity4" box
- in the lefthand property window, select the "Rows" property and open the "Row Collection Editor" by clicking on "..."
- remove all three members in the row collection editor
- apply the changes
the application now crashes with beforementioned exception. Is there a way to tell the flowchart control that the box content has changed or should the control figure this out by itself ?
tnx
Re: Modifying Table in PropertyGrid causes crash
Reply #1 - Oct 31st, 2007 at 3:32pm
At this time the control does not track changes that you do directly to the Rows or Columns collections of a table. Use them only for read access to the rows and columns. You must call the DeleteRow method to delete a row, or you could set the table's RowCount property to a smaller value.
rfuegen
Reply #2 - Dec 5th, 2007 at 2:38pm
tnx for the answer.
If I remember correctly, when displaying the chart I can't prevent the user from deleting rows from a table. Am I right or can this be prevented ?
cu
Stoyo wrote on Oct 31st, 2007 at 3:32pm:
Reply #3 - Dec 5th, 2007 at 5:20pm
If you display the table properties in a property grid, the user will be able to delete rows by setting a smaller RowCount value. You could display only a subset of the table properties as shown in the Flowcharter sample project.
