Normal Topic Maximum scroll position (Read 2586 times)
Darko
Nov 1st, 2007 at 10:49am
I'm trying to implement the mouse wheel scrolling to work with the calendar control.
It works, except that the VScrollPos doesn't change if I set it to the value above maximum (or below 0). As I increase/decrease the scroll position with the number specified in the SystemInformation.MouseWheelScrollLines constant (which is usually 3), the scroll position doesn't change if the (maximum scroll position - current scroll postion) is less than 3.
Here is my code:
[code]
void control_MouseWheel(object sender, System.Windows.Forms.MouseEventArgs e)
if (Math.Abs(e.Delta) == 120)
calendar.VScrollPos += -e.Delta * SystemInformation.MouseWheelScrollLines / 120;
}[/code]
Is there any way to retrieve the maximum vertical scroll position (or any other solution except for checking whether the value did change or not)?
Darko
Re: Maximum scroll position
Reply #1 - Nov 1st, 2007 at 12:06pm
It appears that Calendar.VScrollPos and Calendar.HScrollPos do nothing if the specified value is out of the valid scroll range. I have found the following workaround however:
calendar.ScrollPosition = new Point(
calendar.ScrollPosition.X,
calendar.ScrollPosition.Y + -e.Delta * SystemInformation.MouseWheelScrollLines / 120);
Darko
Reply #2 - Nov 2nd, 2007 at 12:27pm
thanks. It works as it should now.  Smiley
Cheers,
Darko
