Normal Topic AnchorPoint (Read 2465 times)
Luca
AnchorPoint
Nov 14th, 2007 at 7:06pm
Hello!, We are using version 4.3 of FlowChart.NET
i have 2 boxes y each box with 3 anchor points and 3 arrow each one conected to a one origin anchor to dest anchor.
The propierty
diagram1.AllowUnanchoredArrows=false.
When i call to ReassignAnchorPoints function i have a problem because  in sometimes the arrow is connected directly to the Box instead of the anchors
How can I control that this will not happen?
I test this issue in the 5.01 and the same thing happens...
Thanks for your help and sorry for my English;)
Re: AnchorPoint
Reply #1 - Nov 14th, 2007 at 7:18pm
Does your application handle the ValidateAnchorPoint event? Could you post here your code that defines the anchor points and creates the links?
Luca
Re: AnchorPoint
Reply #2 - Nov 14th, 2007 at 8:03pm
The Boxes and the arrows are created manually on the flowchart
[code]
private void Form1_Load(object sender, EventArgs e)
fc.ShowAnchors = ShowAnchors.Always;
fc.SnapToAnchor = SnapToAnchor.OnCreateOrModify ;
fc.AllowUnanchoredArrows = false;
private void fc_BoxDblClicked(object sender, MindFusion.Diagramming.WinForms.BoxMouseArgs e)
short xpercent = (short)(e.RelativePos.X / e.Box.BoundingRect.Width * 100);
short ypercent = (short)(e.RelativePos.Y / e.Box.BoundingRect.Height * 100);
if (e.Box.AnchorPattern == null)
e.Box.AnchorPattern = new AnchorPattern();
e.Box.AnchorPattern.Points.Add(new MindFusion.Diagramming.WinForms.AnchorPoint(xpercent, ypercent,true,true,MarkStyle.Circle));
private void button1_Click(object sender, EventArgs e)
foreach (Arrow oArrow in fc.Arrows )
oArrow.ReassignAnchorPoints();
private void fc_ValidateAnchorPoint(object sender, MindFusion.Diagramming.WinForms.AttachConfirmArgs e)
if (numArrowsEntrada(e.Node, e.AnchorIndex) > 2)
e.Confirm = false;
if (numArrowsSalida(e.Node, e.AnchorIndex) > 2)
e.Confirm = false;
private int numArrowsEntrada(Node node, int anchorIndex)
int total = 0;
foreach (Arrow arrow in node.IncomingArrows)
if (arrow.DestAnchor == anchorIndex)
total++;
return total;
private int numArrowsSalida(Node node, int anchorIndex)
int total = 0;
foreach (Arrow arrow in node.OutgoingArrows)
if (arrow.OrgnAnchor == anchorIndex)
total++;
return total;
[/code]
Re: AnchorPoint
Reply #3 - Nov 15th, 2007 at 6:03am
A link would not connect to an anchor point if the ValidateAnchorPoint handler returns false for all points of a node. Perhaps you should not count the link for which you are calling Reassign when checking how many links are already connected to a point?
