Normal Topic Maximum Links (Read 2775 times)
gringogordo
Flowcharting is my life
baby
Maximum Links
Nov 15th, 2007 at 11:07am
Is there a way to limit
1) the number of links that a shape node will accept in and allow out (preferably one in one out) ?
2) the number of shape nodes of a particular type that can be added to a diagram ?
Thanks.
Re: Maximum Links
Reply #1 - Nov 15th, 2007 at 2:59pm
There are some link and node validation events you could handle to implement that. Since "shape node" is a name from the FlowChart.NET API, I assume you are using our .NET control. The validation events you need to handle are called LinkCreating, NodeCreating and LinkModifying in FlowChart.NET. If you are using FlowChartX, the corresponding event names are RequestCreateArrow, RequestCreateBox and RequestAttachArrow.
gringogordo
baby
Re: Maximum Links
Reply #2 - Nov 15th, 2007 at 3:20pm
Yes thanks I found that if I set the AllowIncomingLinks property to false for the destination in the LinkActivated event it does the job (in case anyone else looks at the forum for this!)
Cheers.
Re: Maximum Links
Reply #3 - Nov 16th, 2007 at 8:45pm
{ moved from FlowChartX / Discussion }
