Normal Topic Xml deserialization speed (Read 2193 times)
mtan9
Nov 20th, 2007 at 2:04am
We're currently using version 4.2.1.26908 and the XmlReader deserialization of large flow charts (> 400 items) takes quite a while (~45 sec). I had a few questions regarding this:
1. Has the XML deserialization speed been improved in the FlowChart.LoadFromXml in v5?
2. Can the FlowChart.LoadFromXml read previous version's XML strings?
3. In v5, is there a performance difference between the LoadFromXml overload which takes a document vs. the one which takes a string?
Thanks in advance.
Micah Tan
Re: Xml deserialization speed
Reply #1 - Nov 20th, 2007 at 8:26am
Do you display some large images in the nodes?
We've done some tests with 400 nodes and 400 links:
V4.2, without images: the file loads for a second
V5.0, without images: the file loads for a second
V4.2, with 10 images: the file loads for 12 seconds
V5.0, with 10 images: the file loads for 2 seconds
Each image from the last tests is assigned to 40 nodes. In this case the speed in version 5 is better because the bytes of shared images are encoded and saved just once; whereas version 4 saves a separate copy for each node, and subsequently decodes 400 image copies when loading.
Because version 5 uses the DOM API and version 4 uses linear serialization, the XML serialization is a bit slower in V5 when not using images, or when they are not shared between nodes.
Yes; actually you must use the LoadFromString method to load an XML string.
The latter calls the former after creating an XmlDocument object from the string content.
mtan9
Reply #2 - Nov 21st, 2007 at 5:42pm
Thanks for the quick reply. I checked the performance of the Release/Debug builds outside of the debugger and I was able to get close to the same number that you listed.
Is there a reason why the performance is so different between running in the debugger and running the debug build outside of the debugger?
Reply #3 - Nov 21st, 2007 at 6:07pm
It seems there's lots of stuff going on while the debugger is running, so it might slow down the code execution considerably:
http://www.developerfusion.co.uk/show/4692/
