Normal Topic invalid Child Node Redraw problem (Read 2116 times)
fluber
Nov 21st, 2007 at 7:41am
hi.
  I write a test program reference with TreeLayout demo.
  I build tree relation nodes, and some nodes have a parallel relation node, which does not use AttachTo method.... and I collapse the root node, but I still see the parallel relation node.
diagram.NodesExpandable = true;
diagram.RecursiveExpand = false;
Fluber Wang
Re: invalid Child Node Redraw problem
Reply #1 - Nov 21st, 2007 at 8:34am
Do you mean the parallel relation node DOES use AttachTo? In that case you would have to set the mainNode.SubordinateGroup.Expandable = true to have the attached nodes hide when the tree is collapsed.
Otherwise, if the parallel node is connected to the tree with a link, please check the link direction. Collapse/expand works only in one direction, as set through the ExpandOnIncoming property.
