Normal Topic Printing a diagram (Read 2206 times)
amatta
Printing a diagram
Nov 21st, 2007 at 7:44am
I want to print a diagram with the standard built-in Print-function. So I modify the "Telephone"-Sample and integrate a new menu-Item (PrintPreview).
Here the source:
    Private Sub _menuItemPreview_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItemPreview.Click
       _view.PrintOptions.DocumentName = "Flowchart"
       _view.PrintOptions.EnableImages = True
       _view.PrintOptions.EnableInterior = True
       _view.PrintOptions.EnableShadows = True
       _view.PrintOptions.ScaleToPage()
       _view.PrintPreview()
    End Sub
But the output is not readable. The images are not scaled (some are not visible, too) and the textlines are not aligned. There is really no WYSIWYG layout of the diagram.
What did I wrong? Is there a bug in the printig tool?
Thanks, regards
Andreas
Re: Printing a diagram
Reply #1 - Nov 21st, 2007 at 8:38am
Are you using MeasureUnit == Pixel? This does not work well with printing because the printer pixels are much smaller than the screen ones. Try how that will work if you switch to Point before calling Print().
