Normal Topic Hiding Java advertisement (Read 2973 times)
KBalquis
Senior developer
Nov 21st, 2007 at 8:29am
Dear All,
has anyone of you managed to hide the "visit us at Java.com" when using the Java applet in NetDiagram?
Re: Hiding Java advertisement
Reply #1 - Nov 21st, 2007 at 8:46am
Have they started displaying advertisements? My version of the Java plugin displays only the Java cup logo while loading. And then when you visit the page the next time, the applet is loaded immediately from the cache and you don't see even the logo? Yet, it might be possible to hide it by starting with a very small applet, and then increasing the size from the AppletStarted event. I will try this and let you know if it works.
Reply #2 - Nov 21st, 2007 at 8:55am
This does the trick - set the Width and Height attributes of the FlowChart to 1 pixel, and assign the following JavaScript function to AppletStartedScript:
function onAppletStarted()
     var fcApplet = <%= fc.AppletElement %>;
     fcApplet.width = 750;
     fcApplet.height = 400;
Replace the size values above with your original width and height. You might have to add a fixed-size div around the flowchart, to prevent the user from seeing the page elements moving around when the applet is resized.
KBalquis
Senior developer
Reply #3 - Nov 21st, 2007 at 9:06am
Thank you very much.
It works Perfectly. Cheesy
