Normal Topic Item.Priority and TimeTable view (Read 1565 times)
MichaelH
Did you not get the memo?
Nov 23rd, 2007 at 8:41am
I am having trouble with the Priority setting for the items inside a timetable view.
Does the start time of the appointment override the priority? When I change the start time of an appointment by resizing it, it will move position. I would like the appointment to stay where it is and not move up or down.
I posted a message before about this but this was to do with the appointment moving whilst resizing.
Is there any way to keep the appointment on the same level after resizing it?
Michael.
Re: Item.Priority and TimeTable view
Reply #1 - Nov 23rd, 2007 at 9:34am
The item priority is only used for items having the same start and end time. Otherwise the start time of the item (and the item duration if both start times are equal) is considered in order to determine the position of the item.
