Normal Topic UndoManager can Ignore box.Move()? (Read 3044 times)
alesdario
Nov 23rd, 2007 at 12:24pm
Hy stoyo.
I'm trying to move a box when the lane where the box is contained is modified. But i'd like that FlowChart.UndoManager will ignore this operation.
private void grid_CellBoundsChanged(object sender, CellBoundsEventArgs e)
    box.Move(box.BoundingRect.X,(e.NewBounds.Top + box.Distance));
In this event i want that UndoManager ignore box.Move. Is it possible?
Tanks.
alesdario
Re: UndoManager can Ignore box.Move()?
Reply #1 - Nov 23rd, 2007 at 1:04pm
As an alternative, is possible to have access to
flow.UndoManager.History.Commands[index] parameters?
Tanks.
Reply #2 - Nov 23rd, 2007 at 1:30pm
Try to filter out the ModifyItemCmd created for the box movement. Set some boolean flag before you start moving the boxes, and in the ActionRecording event handler set Cancel = true when that flag is set and the typeof(command) is ModifyItemCmd.
alesdario
Reply #3 - Nov 23rd, 2007 at 1:51pm
Perfect. Tanks
alesdario
Reply #4 - Nov 23rd, 2007 at 2:01pm
Is also possible set the point where the undoManager will move the box after undoManager.Undo()?
Reply #5 - Nov 26th, 2007 at 7:44am
The node position won't be restored if you filter the command when ActionRecording is raised. You could create a composite command that contains all ModifyItemCmd instances created by the Move method, and also add to it your own command object that resizes the lane grid when undone or redone. Then calling Undo or Redo will move all nodes and resize the lane as a single operation.
