Normal Topic Performance on Pentium 3 (Read 3075 times)
Milo
Nov 26th, 2007 at 10:04am
I've been writing a timetable application, and on my development machine the performance hasn't been an issue. I develop on a P4 and Dual core machine, and adding appointments to the weekview has been instantaneous.
However I've deployed an early beta to the customer site, and they're complaining of peformance issues. They are running P3 600-1ghz machines. I've set the theme to "standard" which has improved perf slightly.
If I fill a month with appointments (one per day) and I click on one day, the highlight takes about 3 seconds to appear. Similarly if I click and select a range this takes a few seconds to update the selection. (I removed all events to check this isn't the issue)
Is there anything you can point me towards improving the calendar for lower spec machines...?
Thanks.
Milo
Re: Performance on Pentium 3
Reply #1 - Nov 26th, 2007 at 11:17am
Can you handle the MouseDown, MouseUp and Draw events of the Calendar control and measure the time they are raised at? You have to select something in the Calendar.CustomDraw property in order the Draw event to be raised.
Milo
Reply #2 - Dec 20th, 2007 at 8:36pm
Ok, what unit do you want the time measured in?
I'll have to knock up a custom version.
Reply #3 - Dec 21st, 2007 at 5:48am
Seconds will be fine as well as long as you are using floating point precision.
Milo
Reply #4 - Jan 22nd, 2008 at 1:33pm
Found my problem, setting props in my gettor accessor.  Embarrassed Embarrassed
