Hot Topic (More than 10 Replies) .net upgrade problem? (Read 5240 times)
wangqaa
Nov 27th, 2007 at 12:43am
Hi:
We have used FlowChart.net 4.1(WebChart.NET) and ASP.net 1.1 to develop web ap for months.
Now we want to upgrade to .net 2.0. What problems will we confront or how can we make it?
My "ex"- partner told me he tried it for some times,but it didn't work. He said "automation problem" can't be sloved.
Or other suggestion: use other product such as
"NetDiagram"?(it means I need to recode all the program Embarrassed?)
Whatever, we hope easily upgrade our
.net framework and constantly reuse FlowChart.net code.
We need your treasure advise~ ???
« Last Edit: Nov 27th, 2007 at 2:01am by wangqaa »
Re: .net upgrade problem?
Reply #1 - Nov 27th, 2007 at 7:00am
I presume the "automation problem" is the "Object does not support automation" error message, displayed when you try to access the control's API from JavaScript. Unfortunately we could not find any way to avoid this. The same flowchart.dll is considered automation-compatible and works fine when loaded under .NET 1.1, but the .NET 2 runtime decides it is not automation-compatible and does not allow accessing the control's methods.
A work-around is to access the Flowchart.NET API entirely from .NET, using a wrapper control that implements your application's client-side logic. I guess that would be a problem if you have a lot of JavaScript code. You might try to implement your wrapper control in the .NET JScript language instead of C# / VB.NET. That should let you reuse most of your JavaScript code.
Once you have the wrapper control's dll compiled, you can load it via the OBJECT element instead of the flowchart.dll.
wangqaa
Reply #2 - Nov 28th, 2007 at 12:13am
Thanks for your kindly reply~
I'll try it.
wangqaa
Reply #3 - Nov 30th, 2007 at 6:28am
Hi:
I try some condtions with .net 2 & WebChart.dll(4.2)
I first transfer my old project .net 1.1 to 2.0 . it's ok.
Then I change the WebChart.dll 4.1 for 1.1
to WebChart.dll 4.2 for 2.0.
I covered all the refernce.
But "System.IO.FileLoadException" happened.
it shows can't load file or assembly 'WebChart.NET, Version=4.1.0.23493, Culture=neutral, PublicKeyToken=daa805bd79929376'
but I changed to 4.2 ,why it shows can't load 4.1.
Can you tell me how to upgrade .dll like this?
thanks~
Reply #4 - Nov 30th, 2007 at 7:58am
Check if the common.dll reference correctly points to the .NET 2 version too. In addition, in the references property page enable "Copy local" and disable "Specific version".
wangqaa
Reply #5 - Dec 4th, 2007 at 10:34am
I tried to follow your comment.
I get the MindFusion.Common.dll from
C:\Program Files\MindFusion Limited\FlowChart.NET Pro\VS2005 (.NET 2.0)
and reload  the project's  reference.
But it doesn't change the error message.
How to check MindFusion.Common.dll correctly points to the .NET 2?
or How to really reload the dll?
Thanks~
Reply #6 - Dec 4th, 2007 at 12:46pm
The project's reference path might lead to getting the common.dll from another folder. Check the "resolved path" property of the common.dll reference to see exactly which version is used.
wangqaa
Reply #7 - Dec 6th, 2007 at 1:24am
the reference problem sloved. Thank you!
Back to the automation problem...
you said:
"implement wrapper control in the .NET JScript language"
We have no idea about it. Did you try it?
or Show some simple example..
I'll study it....
If you have had some result of it.
It will be helpful to us.
ps.We really want to continue use your product.
     If all the upgrade problem solved.
thanks~
Reply #8 - Dec 6th, 2007 at 7:03am
Here is a sample wrapper control:
https://www.mindfusion.org/_FcnetWebWrapper/FcnetWebWrapper.zip
An html page that shows the wrapper is available here:
http://www.mindfusion.org/_FcnetWebWrapper/FcnetWebWrapper.htm
It uses version 5 of the control, but you can use the same technique to create a wrapper for Flowchart.NET 4. Just for an example, the wrapper handles the NodeCreated event in .NET Windows Forms code and displays a string when a node is created.
It seems that VS does not provide built-in support for using JScript in Windows Forms, so this sample project is implemented in C#. You might have to use a command line compiler if you decide on using JScript.
Note that we have used the ILMerge tool to merge the wrapper and Flowchart.NET assemblies into a single dll. This is not strictly necessary - it should be possible to deploy all dlls in web folder and the .NET loader will download them when necessary. Anyway, in the .zip archive you will find a batch file that shows how to run ILMerge.
wangqaa
Reply #9 - Dec 7th, 2007 at 4:37am
Thanks for your reply.
I found some phenomenon of the automation problem.
Not all methods can't support automation .
When I marked some flowchart method code in javascript.
It still work.
such as
"UndoManager.UndoEnabled"
"PrintOptions.EnableBackgroundImage"
it can't work
Do you have any idea of these?
thanks~
Reply #10 - Dec 7th, 2007 at 7:05am
Yes, the problem is with types different than FlowChart, e.g. UndoManager, PrintOptions, Arrow, Box, etc. It seems the .NET 1 runtime creates automation proxies for all types from the Flowchart.net.dll, whereas .NET 2 creates one only for the FlowChart class, probably because it is directly referred to through the OBJECT element. We have tried a lot of things to make those types "automation compatible" when loaded by .NET 2, but unsuccessfully...
wangqaa
Reply #11 - Dec 20th, 2007 at 11:31pm
New problem...
our user used the IE 7 to view our chart
also have "automation problem".
We use iexplore.exe.config in client
<startup>
<supportedRuntime version="v1.1.4322" />
</startup>
but it doesn't work?
Do you have this problem before?
thanks
Reply #12 - Dec 21st, 2007 at 6:22am
We haven't had any problems with IE7 when using .NET 1.1. Are you sure your user has the .NET 1.1 runtime installed on their system?
wangqaa
Reply #13 - Dec 28th, 2007 at 4:39am
it's ok~
our setting error...
thank you~ Smiley
