Normal Topic Grouping boxes inside other boxes (Read 2744 times)
Laser
Nov 30th, 2007 at 3:40am
Hi.
Is it possible to create parent boxes, that may contain groups of child boxes inside?
The idea is to be able to move the parent boxes, without changing the relative positions of the child boxes.
When selecting and moving a parent box, everything inside should behave as a group.
Is FlowchartX capable of this?
Re: Grouping boxes inside other boxes
Reply #1 - Nov 30th, 2007 at 5:36am
Call FlowChart.CreateGroup(parentBox), and then use the group's AttachTo_ methods to add the child boxes.
Laser
Reply #2 - Nov 30th, 2007 at 6:18am
Do you have any VB example where I can see the behavior of this?
Thanks a lot for your attention.
Reply #3 - Nov 30th, 2007 at 7:55am
Check the Genealogy sample project. The female/male icons there are boxes attached to the main image box using a Group object. Double click on the flowchart canvas to create the group.
