Normal Topic Custom Shape (Read 1986 times)
feege
Custom Shape
Dec 10th, 2007 at 2:27am
I am trying to get the code to work that defines a custome shape.
I have copied this code into my .NET webform
private void example_Click(object sender, System.EventArgs e)
           // define a custom shape
           // this is the same as: fc.DefaultShape = ShapeTemplate.FromId(“Tape”);
           fc.DefaultShape = new ShapeTemplate(
                 new ElementTemplate[] {
                       new LineTemplate( 50, 100,  85, 100),
                       new LineTemplate( 85, 100,  85,  90),
                       new LineTemplate( 85,  90,  70,  90),
                       new BezierTemplate( 70,  90,  85,  90, 100,  75, 100,  50),
                       new BezierTemplate(100,  50, 100,  25,  75,   0,  50,   0),
                       new BezierTemplate( 50,   0,  25,   0,   0,  25,   0,  50),
                       new BezierTemplate(  0,  50,   0,  75,  25, 100,  50, 100) },
                 FillMode.Winding);
But I get an error message that says "The name 'FillMode' does not exist in the current context"
Can someone help me here please
Geoff
Re: Custom Shape
Reply #1 - Dec 10th, 2007 at 6:48am
FillMode is defined in the System.Drawing.Drawing2D namespace, so you should either import the namespace using an Imports directive, or use the fully qualified type name: "System.Drawing.Drawing2D.FillMode.Winding". If you need to use this shape in applet mode, you will have to save it in a shape library file, and assign the file URL to the ShapeLibraryLocation property.
