Normal Topic "Light" version of NDiagram (Read 4159 times)
KBalquis
Senior developer
Dec 17th, 2007 at 11:36am
Am using NDiagram to allow users to create their own flowchart and I save them into a database.
I have a user who is allowed to "view" the flowcharts. however, it takes long time to load the applet. Is there a way to enhance the performance of the applet loading? or is there a light version of the applet that is used for viewing without allowing the user to interact with the applet?
Regards
Re: "Light" version of NDiagram
Reply #1 - Dec 17th, 2007 at 12:21pm
You could set ClientSideMode to ImageMap for users that don't need interactivity. That mode does not require loading the applet at all. Otherwise, set Behavior to DoNothing to prevent the user from modifying the flowchart when in applet mode.
You can create a lighter version of the applet by opening the .jar file and removing the classes that won't be used in view-only mode (e.g. layout classes). Then you can set JarLocation to the full applet for users that can edit the flowchart, and set it to the lighter applet for users that will only view the flowchart.
KBalquis
Senior developer
Reply #2 - Dec 21st, 2007 at 10:31am
Thank you Stoyo, it works great  Grin
is there a way to disable the PostBack upon clicking a box?
Reply #3 - Dec 21st, 2007 at 12:57pm
Yes, you could add an empty BoxClickedScript, or set the Hyperlink property of all boxes to "javascript:void(0)".
KBalquis
Senior developer
Reply #4 - Dec 21st, 2007 at 2:34pm
Thank you  Grin You are really being a great help to me.
Reply #5 - Dec 21st, 2007 at 2:34pm
