Normal Topic Collection was modified: enumeration operation may (Read 3980 times)
elpuerco
Time?  What's time matta
to a pig?
Dec 18th, 2007 at 2:40pm
I had a search for this error and only came up with this thread which does not help me on this instance, although as my application will be multi user the delegate snippet will be useful to test.
http://mindfusion.org/cgi/Forum/YaBB.pl?action=search2
However, following on from the grouping by locations I find I have another problem.
I have two calendars, one in month view and the other in time table view.
calmonth is linked to caltime so every time a user amends caltime the highlighting is updated accordingly on calmonth.
All works great except when I change location I get the error listed in thread subject on this code:
  For Each s In Me.calMonthView.DayStyles
			  Me.calMonthView.DayStyles.Remove(s)
 Next
This code is used in a different place in response to users deleting and appintment and is in an if statement which tests the day/time and removes is required and works ok.
I have not restricted to a day/time as it needs to clear the entire style so that when moving from one location to the other the previous locations styles are cleared before the new locations styles are drawn.
I hope I make sense?
Re: Collection was modified: enumeration operation
Reply #1 - Dec 19th, 2007 at 6:19am
You have to either stop the loop immediately once the collection is modified or (if you need to delete more than one object from the collection) you have to do this in an ordinary For loop. Otherwise, the enumerator throws an exception if its underlying collection was modified.
elpuerco
to a pig?
Reply #2 - Dec 19th, 2007 at 10:35am
Is this something specific to Planner.NET?  I thought if I cycled thru the collection it would only process those that were found in it?
However when I try it this way:
 For x = 0 To Me.calMonthView.DayStyles.Count - 1
	 Me.calMonthView.DayStyles.RemoveAt(x)
 Next
I do not get the error which is good but the highlight does not get removed?
elpuerco
to a pig?
Reply #3 - Dec 19th, 2007 at 10:55am
I also try this with no results:
     s = Me.calMonthView.DayStyles(x)
 Next
I see in the Planner.NET help that RemoveAt is not listed?
elpuerco
to a pig?
Reply #4 - Dec 19th, 2007 at 12:05pm
OK I have now tracked it down to this bit of code!
The RemoveAt works a treat, however the code below redraws the highlight.
Me.calTimeTableView.LoadFromDataSource()
' clear the calendar locations
Me.calTimeTableView.Locations.Clear()
' add the location chosen by user on form
Me.calTimeTableView.Locations.Add(Me.calTimeTableView.Schedule.Locations(intBuilding))
' and set calendar to group by location
Me.calTimeTableView.GroupType = GroupType.GroupByLocations
' cycle through timetableview items in order to update monthview highlighting
For Each itemMonth In Me.calTimeTableView.Schedule.Items
    ' for every item in the timetableview process it into the monthview
	ProcessItemCreated(itemMonth)
 Next
So my confusion is this...
If I have grouped by location and the user has selected location 2 why does the code above process all locations 1 and 2?
I can see I am obviuosly not graspng the full functionality of the Planner control!
Reply #5 - Dec 19th, 2007 at 12:18pm
The Schedule.Items collection contains all items regardless of whether they are displayed in the calendar or not. If you are interested in processing only the items matching certain criteria (only those that are associated with a particular location in your case), you have to do this manually. Simply add a condition before processing an item, which tests whether the item is associated with the appropriate location.
elpuerco
to a pig?
Reply #6 - Dec 19th, 2007 at 1:03pm
Yep, I was on to that before I came back to read your post  Grin
Here is the working result:
   Select Case intBuilding
	Case 0
	     If itemMonth.Location.Name = "WHSE1" Then
	     End If
	 Case 1
		If itemMonth.Location.Name = "WHSE2" Then
		End If
	  End Select
Next
Grin Grin
