Normal Topic TableNode disobeying cell TextFormat rules (Read 3098 times)
consolejoker
Dec 29th, 2007 at 4:17am
I have a 2 column table node. I have set the 2nd column to have a string that is longer than fits in the cell.
By default it wraps and does an ugly line break. So I did the following:
		Node[1, 0].TextFormat.FormatFlags = StringFormatFlags.NoWrap;
		Node[1, 0].TextFormat.LineAlignment = StringAlignment.Center;
		Node[1, 0].TextFormat.Alignment = StringAlignment.Near;
		Node[1, 0].TextFormat.Trimming = StringTrimming.EllipsisCharacter;
I've tried just about every combination and the best I can get it to do is to not break a line, but it ends up being right justified, even when I set it to be aligned to Near.
I've spent about an hour on it so I'm going to move on but hopefully someone can point me in the right direction.
Thx.
Re: TableNode disobeying cell TextFormat rules
Reply #1 - Dec 29th, 2007 at 5:50am
Try that with EnableStyledText = false. At this time our text formatting algorithm used with styled text does not support StringTrimming.EllipsisCharacter. However, even with enabled styled text, I could not reproduce the alignment problem - I'm getting left-justified text, and the only difference from the standard .NET formatting is the missing ellipsis. Could you post here the code you are using to set up the table?
consolejoker
Reply #2 - Dec 29th, 2007 at 6:59am
Here's my pretty insane code, which is a hack of many different experiments so who knows what damage I may have done Smiley
« Last Edit: Dec 29th, 2007 at 3:45pm by consolejoker »
Reply #3 - Dec 29th, 2007 at 7:16am
I've tried this with your code, and the text in the second column is still left justified. Some TableNode property values are initialized from the Diagram's properties when you use that constructor, so could you also post your Diagram initialization code? Smiley
« Last Edit: Dec 29th, 2007 at 7:15pm by Stoyo »
consolejoker
Reply #4 - Dec 29th, 2007 at 8:03am
OK nevermind that stuff I just posted. I figured it out.
Get this, I was giving the *caption* 10 blank character spaces preceeding the actual caption text because I could not get the darn thing to be in the center of the caption bar, so I had to force it with blank space.
That apparently was messing up the table rendering so I guess this is a bug because it shouldn't affect it.
Removing the blank space fixed it, but now my caption is far left justified. Even setting the caption format to Far does not affect it, its still full flush left as far as can be and underneath my icon.
Reply #5 - Dec 29th, 2007 at 9:45am
This worked fine in my test:
tableNode.Caption = "Centered";
tableNode.CaptionFormat.Alignment = StringAlignment.Center;
There is a
tableNode.CaptionFormat.Alignment = StringAlignment.Near;
assignment further down in your code. Perhaps it overrides the alignment if you add the Center assignment just after setting the caption (as had happened in my case before removing it)?
consolejoker
Reply #6 - Dec 29th, 2007 at 4:10pm
Thanks, yes my stupid code was the problem.
So basically the recap for anyone following along is that extra blank text in the caption may cause wrapping issues for the cells of the table.
This is not a problem now since I now properly have used the caption format property and removed the redundant assignment.
Thanks Stoyan for all your help these last few days. I am starting to see how the API works and it is quite powerful and fast!
