Page Index Toggle Pages: 1 2 3 [4]  Send TopicPrint
Very Hot Topic (More than 25 Replies) WPF (Read 52678 times)
Paul Eden
Re: WPF
Reply #45 - Dec 7th, 2007 at 4:04pm
Hi Stoyan
Once again thank you for the pointers - the resizeToFitItems worked a charm - one call after all work carried out and the user won't know it happened Smiley
Is it possible to programaticly create diagram links to connect items on the diagram that are not diagramNodes?
I see that when i put a break point in the LinkCreating event, a DiagramAdaptorNode is used, but it would seem this is private to the Mindfusion DLLs?
Re: WPF
Reply #46 - Dec 7th, 2007 at 6:29pm
Hi Paul,
The control uses an attached property to associate whatever framework element you add to the diagram with its adapter node. You can get the node like this:
DiagramNode adapterNode = (DiagramNode)Diagram.GetDiagramItem(fwkElement);
Paul Eden
Re: WPF
Reply #47 - Dec 14th, 2007 at 2:32pm
As usual, spot on - thanks.
Also, as usual, the answer precedes another question Smiley
I'm working with groups now; i can create a group via the factory method and it is created with the main node that I provide, but I can't see a way of  adding more nodes to the group as there is no 'AddNode' method - version 4 used the AttachedBojects.Add method.  Is this method missing or should items be added to groups in a different manor?
Many thanks
Paul
Re: WPF
Reply #48 - Dec 14th, 2007 at 4:34pm
Hi Paul,
You can use the node.AttachTo(main, ...) method to add nodes to groups. This will add the node to the main's SubordinateGroup, creating the group if it hasn't been created yet.
You could also use the groups' AttachToCorner / AttachToSegment / AttachToPoint methods to add child nodes.
Paul Eden
Re: WPF
Reply #49 - Jan 14th, 2008 at 9:37am
Hi Stoyan
I see we have our dedicated WPF forum  now Smiley
Does this mean there is a WFP official beta imminent?
Re: WPF
Reply #50 - Jan 14th, 2008 at 10:01am
Yes, we are creating the msi package now, and the first version should be available this week Smiley
